21 Users Online (19 Members):
Forums >> Revit Structure >> Technical Support >> Cellular Beam Families
3 Posts No Rating |
Hi All, This is my first post. I'll get straight to the point... I'm using Revit Structure 2011 and I am working on a project that requires lots of cellular beams. I have had no problem creating the beams using an existing family. however, I now need to edit the family in order to set the holes in the beams out differently in certain scenarios. One case I am particularly struggling with is this. I need my holes at fixed 600c/c, easy! I then need to set them out so that the centre of the beam is the middle point between two holes (300mm from each nearest hole centre). I have no idea how to edit arrays in families and any help would be much appreciated. Thanks in Advance! Lee C
Cellular Beam (File Attached) |
Tue, Feb 15, 2011 at 3:32:48 AM
cellular beam interuptions |
Fri, Oct 9, 2009 at 1:39:47 PM
Remove individual holes from cellular beams |
Tue, Jun 17, 2008 at 1:02:33 PM
Cellular beams |
Mon, May 7, 2012 at 7:05:51 PM
Celluar Beam Handles (grips) |
Tue, Jan 10, 2017 at 8:05:17 AM
