14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Scheduling Coordinate Points for Complex Geometry
2 Posts No Rating |
Hello All, I am trying to efficiently document complex exterior wall geometry. I was hoping to use spot coordinates that could show the X,Y,Z components from a set 0,0. Then, be able to set up the X,Y,Z components in a schedule which will have to be exported to Excel. Any suggestions? Has anyone used the Excitech tool for Revit 2011? Any help would be greatly appreciated!
Check out the extensions availble with your subscription . I thik this is the one you are looking for: http://www.extensions4revit.com/n/e4r/856/60 Then by using a family that will schedule using this extension - you got it. That family might be just a point?
2 Posts No Rating |
Thanks, WWHub! I am looking for something that would read the coordinates without manual input, do you know if this might do that? I will research this extension a little further, too. Thanks again...
Creating Complex geometry |
Wed, Nov 16, 2005 at 2:59:35 AM
Scheduling Topographic points |
Mon, Sep 28, 2009 at 7:52:43 PM
Families - Locking complex geometry |
Thu, Dec 4, 2014 at 10:48:22 AM
Mass Geometry Flaw | Circle points |
Fri, Dec 4, 2015 at 4:04:46 PM
Allow 3 point Definition for Reference Planes |
Mon, Mar 28, 2005 at 8:53:52 PM
