9 Users Online (8 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Top of Steel / Bottom of Deck Elevation using a Spot Elevation?
Thu, Jan 20, 2011 at 5:06:06 PM | Top of Steel / Bottom of Deck Elevation using a Spot Elevation?
Wildcat7
Wildcat7 Avatar
As anyone developed a spot elevation that calls out the bottom of steel deck / top of steel beam elevation?
Fri, Jan 21, 2011 at 2:04:46 PM | Top of Steel / Bottom of Deck Elevation using a Spot Elevation?
gregroberson
gregroberson Avatar
I have some spot elevations where I edited the type, renamed it el_DBE or el_TBE.  the only item I modified was the TEXT parameter "Elevation Indicator".  I typed in DBE: and TBE:, respectively.  Is this what you mean?
Greg
sloping steel roof deck problem
Wed, Mar 5, 2008 at 5:55:12 PM
Spot Elevation tag
Tue, May 6, 2014 at 12:41:09 PM
ceiling tag to read as spot elevation (top or bottom elevation) (2017)
Tue, Aug 28, 2018 at 10:51:10 AM
Steel Beam spot elevation
Wed, May 7, 2008 at 6:26:17 PM
Spot Elevation
Thu, Apr 28, 2011 at 3:46:55 PM
Page generation time: 0.6041
