25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> What is the best way to copy walls from one level to another?
26 Posts No Rating |
I tried doing this in section and it seems to work ok. Revit does not let you do it from the plan. Any suggestions?
section, or 3D view with a section box. Or in wireframe. Make sure to uncheck "constrain". You can copy upward in plan (basically) if you copy to the side some rational number, like 3 feet, change the paramters to be up a floor, and then move it back 3 feet while you still have it selected.
If you want interior layouts... walls - doors - rooms - furniture - text - dimensions - tags - whatever, copied level to level, select all the items, copy to clipboard and "paste aligned to selected levels". There you can pick multiple levels.... paste all in one operation. And you cvan do this from plan views.
Edited on: Thu, Jan 20, 2011 at 3:57:55 PM
ok cool and tried this and it works great!
copy groups from level to level |
Fri, Feb 5, 2010 at 7:55:06 AM
Can't copy furniture group to different level view |
Thu, Jun 7, 2018 at 10:43:54 AM
Collaborate - Copy command changes type |
Fri, Nov 6, 2015 at 1:35:14 PM
Walls show up on Second Level plan |
Wed, Dec 19, 2018 at 8:39:24 AM
Copy Dimensions |
Fri, Oct 10, 2008 at 7:26:58 AM
