Forums >> Revit Building >> Technical Support >> Curved Angled Glass Walls
Thu, Jan 20, 2011 at 12:44:39 PM | Curved Angled Glass Walls
NickDesert
3.5 Stars: 3 Votes
Hey everyone,
I am currently having MAJOR problems with creating curved angled glass walls. I have to build 15 walls which are angled to the same degree as my columns. I have tried creating masses, which I finally managed to.. only to have Revit tell me that I cannot use the mass to create a glass wall, even though I managed with one already.
I have attached some images of the building, if anyone has any suggestions as to how I can put the walls in they would be greatly appreciated.
Thanks,
Nick
Thu, Jan 20, 2011 at 1:01:41 PM | Curved Angled Glass Walls
MADnes
WHAT METHOD DID YOU USE TO CREATE YOUR MASS, EXTRUSION, SWEEP ETC...?
Gabriel Flores AAS/CDD, BS/CM
Thu, Jan 20, 2011 at 1:02:57 PM | Curved Angled Glass Walls
4 Stars: 205 Votes
Did you create the "Mass" then create a "Curtain System" by face?
Thu, Jan 20, 2011 at 1:23:47 PM | Curved Angled Glass Walls
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Hey there,
 That's right, you use a curtain system, instead of trying to apply a curtain -wall- by face.  If you don't want to use massing, you can build a swept blend in the generic model category, and then hide it.
attached is a picture of a curtain system applied to a swept blend face.  You may need to make a new curtain system type, the default is 5x10 panels.
Edited on: Thu, Jan 20, 2011 at 1:24:24 PM
Thu, Jan 20, 2011 at 3:01:49 PM | Curved Angled Glass Walls
NickDesert
3.5 Stars: 3 Votes
Thanks,
 I managed to align a level to the top of each of the columns so that I could make masses that go all the way to the underside of the roof.
Apparently the method I was using before wasn't working... But I can now create the masses and create curtain wall system from face... Thanks!!
curved angled curtain walling
Wed, Mar 8, 2006 at 4:18:50 AM
Angled Walls in Revit
Mon, Jan 12, 2015 at 8:48:26 AM
Making Angled or canted walls
Tue, Jun 3, 2008 at 2:10:07 PM
angled corner joint - how to lock angled corners
Thu, Jul 18, 2013 at 5:10:11 AM
11
Revit 2011-putting openings in angled walls.
Sat, Sep 10, 2011 at 5:45:27 AM
Page generation time: 1.3602
