15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> PROBLEMS EXPORTING GRAPHIC COLUMN SCHEDULE TO AUTOCAD
12 Posts No Rating |
I AM HAVING PROBLEMS EXPORTING MY GRAPHIC COLUMN SCHEDULE TO AUTOCAD FROM REVIT STRUCTURES 2011. WHEN I EXPORT IT THE RESULT IS MY COLUMNS AND TAGS ARE THE ONLY THINGS EXPORTED. THE TABLE AND TABLE HEADINGS ARE MISSING. I HAVE TRIED TO FIGURE OUT WHAT LINE TYPE I MAY BE MISSING IN MY EXPORT TRANSLATION, BUT I HAVE BEEN UNSUCCESSFUL THUS FAR. I HAVE EVEN TRIED TO EXPORT USING THE STANDAR AIA TRANSLATION, WITH THE SAME RESULT.
Gabriel Flores AAS/CDD, BS/CM |
I have the same problem. I am not sure why the schedule does not export. I do have a workaround given to me by Melinda Beham on AUGI: Freeze the column schedule using the "Freeze Drawings" command in the Revit Extensions. This will create a drafting view that you can export to AutoCAD and the entire schedule will export.
Showing splices in graphic column schedule |
Fri, Nov 20, 2009 at 9:05:15 AM
Crop Region and Graphic Column Schedule |
Thu, Jan 2, 2014 at 6:13:52 PM
Graphic Column schedule |
Thu, May 23, 2013 at 3:17:49 PM
Column Schedule |
Mon, Apr 21, 2008 at 7:35:29 AM
Column Schedule Help!!! |
Fri, Feb 20, 2009 at 11:39:39 AM
