Forums >> Revit Structure >> Technical Support >> Worksets
Thu, Jan 20, 2011 at 7:24:34 AM | Worksets
cundall
does anyone know of any good tutorials or good web pages with an easy to understand way of learning Worksets.
i can not seem to get to grips with it and i am struggling when im working on big projects.
regards
Thu, Jan 20, 2011 at 8:29:39 AM | Worksets
Worksets are a great tool but they can be miss-used.
  1. Read all the workset topics in your HELP
  2. First rule is the fewer worksets, the better.  Just because you can seperate elements by level does not mean you should.  In our office, other than linked files, we usually only have Shared Levels and Grids, Workset One, Exterior Shell and Interiors.
  3. You don't have to check-out a workset to modify it, you can borrow elements in the workset.
  4. Do use seperate worksets for each linked file
  5. Do use a seperate workset for logical visual seperations.... for instance... interior furnishings are a good candidate to place on a seperate workset, as is something like Owner provided elements.  On multi-bid projects, we prefer worksets over phases.
Cant Delete one of My worksets...please help
Thu, Feb 14, 2019 at 1:48:12 PM
13
cannot enable worksets
Tue, Jan 23, 2018 at 11:00:18 AM
13
WORKSET - problem moving elements to the appropriate worksets PLEASE HELP
Wed, Feb 1, 2012 at 5:04:15 PM
Worksets question - standards question...
Wed, Oct 21, 2009 at 7:28:40 AM
Tue, Oct 23, 2007 at 2:36:13 PM
Page generation time: 1.5893
