Forums >> Revit Building >> Technical Support >> Symbol's families instance length parameters don't change graphically
Wed, Jan 19, 2011 at 6:40:40 PM | Symbol's families instance length parameters don't change graphically
cobblea
(revit 2011)
Hello everyone - I was trying to make a symbol family that would work as a partial dimension.  It would be intended for use in details where you want to show a dimension, but don't want to bother showing the far end of the dimension, as in a sill detail; the sill would take on a witness line, and the arrow would point downwards to a finish floor, or some other datum line.
The attached file should have instance parameters set up for length and height, but neither one seems to have the handy little blue arrows that let you graphically stretch it in a project environment.  Is this a limitation of Symbols (generic annotations), or perhaps I am missing something?
Thank you in advance for any help.
Thu, Jan 20, 2011 at 11:48:04 AM | Symbol's families instance length parameters don't change graphically
MADnes
I BELIEVE THIS IS A SYMBOL LIMITAION. I WOULD TRY TO CREATE IT AS A DETAIL COMPONENT.
Gabriel Flores AAS/CDD, BS/CM
Thu, Jan 20, 2011 at 12:07:53 PM | Symbol's families instance length parameters don't change graphically
TKennedy
4 Stars: 8 Votes
The problem with making it a detail component is it won't change with the scale. Something I have done to work around a similar issue (I was trying to make a better break line) is to nest a symbol in a detail component. In your case, I would try making the tick and arrow head nested symbols, and the rest would be in the detail component. It's a workaround, but it does work.
Can't change Instance's Family. Try changing Instance's Host to a Level first.
Mon, Oct 3, 2005 at 9:29:33 AM
BEWARE - Parameters don't update.
Thu, Sep 1, 2005 at 11:36:58 PM
10 New REVIT 8.1 'Families' Video Tutorials released
Tue, Oct 2, 2007 at 12:39:43 PM
Graphically drive family objects?
Thu, Feb 26, 2009 at 3:44:52 PM
Number of doors depending on length...
Tue, Jan 17, 2006 at 11:42:37 AM
Page generation time: 1.6494
