14 Users Online (12 Members):
Forums >> Revit Building >> Tips & Tricks >> Wall Trickery
As I was chugging away at my model today I came across a rather aggravating little trick within a wall's type properties. Maybe some of you know this already, maybe some don't but you learn something new everyday. Apparently within the wall's type properties, if your wall is set to a "Foundation" function you can't use a level above as the "Top Constraint."Example: I can't have a 12" Concrete basement wall (with a "foundation" function) using the First Floor Level as a top constraint. You will get the "Top Constraint is invalid for the Level" error message, and boy is it aggravating! It must use the Basement Floor Level. Now I can offset it until my heart's desire but it can't associate with a level above. Just a random factoid for the day!
Brandon Pike | Owner/BIM Specialist
cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
4 Posts No Rating |
Thanks for the tip! I fought this recently on a large structural project. Only, when I got the error message it was coming in as an infinite loop and forcing me to shut down Revit. Very aggravating. I never did connect the dots to discover it was only the "foundation" walls causing the problem. But now I know.
Beam System Tags |
Wed, Feb 27, 2013 at 12:55:27 AM
"True" Shadows in Section Box (Section Perspective?) |
Tue, Nov 15, 2011 at 2:31:06 PM
Splitting a curtain wall to change the type of wall it is |
Thu, Aug 6, 2009 at 12:46:42 AM
create a wall sweep on an angled wall (gable end wall) (2017) |
Wed, Aug 3, 2016 at 2:29:53 PM
wall mounted toilet wall error |
Wed, May 6, 2009 at 3:41:37 PM
