Forums >> Revit Building >> Technical Support >> Stairs
Fri, Nov 4, 2005 at 4:45:10 AM | Stairs
Nathan
4.5 Stars: 3 Votes
when you create a flight of stairs how and what command do you use to cut a section out of the ceiling the stairs are cutting through?
Fri, Nov 4, 2005 at 6:39:52 AM | RE: Stairs
Will9000
4 Stars: 5 Votes
Hi Nathan, After craeting your stairs go to the first floor (the floor where you want to cut the opening) go to the element properties dialouge box, (right click - view properties) select underlay and select level 1 (this is to see the stairs on the underside, click ok to exit. Select modelling tab and opening, then pick "pick a face of a roof, floor, ceiling ..........etc. top one i think Click on your floor construction where you want to cut through, and sketch lines where you want the opening to be, press ok and bingo, you can always edit the cut section later if so required, hope that helps, Will
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
stairs not dotted above
Fri, Feb 17, 2012 at 1:44:46 PM
Spiral Stairs around a Central Post
Sat, Apr 16, 2011 at 9:27:29 AM
Help with stairs
Fri, May 4, 2018 at 7:32:59 AM
Page generation time: 1.3264
