16 Users Online (14 Members):
Forums >> Workflow & Implementation >> API & Third Party Apps >> Macro Manager does not like code
26 Posts No Rating |
Below i have included some code that i wrote that basically just draws a line on a plot sheet. It's a test run for another macro that i am trying to code. When i save it with F5 (debugger) nothing comes up and it seems ok. When i get out and try to Run it with Macro Manager, the Run button is deactivated. I know it does not like something in the code but I don't know what?? I am running 2011 on windows xp pro 64. Any ideas would be appreciated. Partial code: using Autodesk.Revit.DB;using Autodesk.Revit.UI;using Autodesk.Revit.Creation;using XYZ = Autodesk.Revit.Geometry.XYZ;using LINE = Autodesk.Revit.Geometry.Line; UIAPPLICATION app = m_doc.Application; //declare variables double x1 = (5.0); double y1 = (5.0); double z = (0.0); double x2 = (7.0); double y2 = (5.0); //create object XYZ point1 = app.Application.Create.NewXYZ(x1, y1, z); //takes doubles XYZ point2 = app.Application.Create.NewXYZ(x2, y2, z); //Create Line LINE line = app.Application.Create.NewLineBound(point1, point2);
sorry about the formatting lets hope this works: using XYZ = Autodesk.Revit.Geometry.XYZ;using LINE = Autodesk.Revit.Geometry.Line;UIAPPLICATION app = m_doc.Application;//declare variablesdouble x1 = (5.0);double y1 = (5.0);double z = (0.0);double x2 = (7.0);double y2 = (5.0); //create objectXYZ point1 = app.Application.Create.NewXYZ(x1, y1, z); //takes doublesXYZ point2 = app.Application.Create.NewXYZ(x2, y2, z);//Create LineLINE line = app.Application.Create.NewLineBound(point1, point2);
ok..so i have attached a file with the code in it-happy trails
51 Posts No Rating |
The code doesn't look properly formatted to me. Does it compile without errors?
no it doesn't thats the wierd thing about it...
Trying to figure out how to code using VB.NET in Macro Manager and I need HELP!! |
Fri, Mar 28, 2014 at 8:16:28 PM
Need help with Macro program for point cloud visibility |
Tue, Apr 25, 2017 at 4:07:38 PM
Cannot grab elements in 2011 using 2010 code |
Mon, Jun 21, 2010 at 5:40:27 PM
Macro request |
Mon, Jul 19, 2010 at 10:35:00 AM
Things necessary for a Good BIM Leader / Manager |
Mon, Feb 22, 2010 at 8:14:39 AM
