Forums >> Revit Building >> Technical Support >> Adding mullions to curtain walls
Wed, Jan 19, 2011 at 3:09:11 AM | Adding mullions to curtain walls
davet
I'm having trouble creating my curtain wall. I need to add mullions vertically and horizontally to create glazed panels. Trouble is the mullions just wont load up. I've tried loading them from the profiles section in families but having no success.
Could anyone give me any advice. Please!
Wed, Jan 19, 2011 at 8:03:02 AM | Adding mullions to curtain walls
From your question, I think you need to spend some time understanding curtain walls.  Here is a good place to learn some of this:  http://revittotd.com/06/225 You will find a whole sequence on curtain walls that will help you there.
Wed, Jan 19, 2011 at 8:34:09 AM | Adding mullions to curtain walls
davet
Thanks. I'm trying to learn this software myself so keep on cutting corners etc.
Thu, Jan 27, 2011 at 12:08:52 PM | Adding mullions to curtain walls
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
sounds like you need to add (curtain grids) before you can add a mullion.
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Curtain walls: Different spacings between mullions.
Tue, Jun 2, 2015 at 9:46:09 AM
appearance of curved curtain walls in plan
Tue, Apr 25, 2006 at 10:10:08 PM
Angled Curtain Walls - fillets and nested
Thu, Apr 23, 2009 at 5:42:47 PM
Corner Mullions
Fri, Dec 6, 2013 at 11:05:58 AM
Reset curtain wall
Tue, Aug 16, 2011 at 7:40:52 AM
Page generation time: 1.4903
