Forums >> Revit Building >> Technical Support >> Exported AutoCAD file is too large
Tue, Jan 18, 2011 at 11:55:58 AM | Exported AutoCAD file is too large
SHANEBOLS1978
I exported an autocad file of a sheet of my project and the file was over 60 MB.  The other exported sheets were under 1 MB.  Can anyone explain why the one file is coming out so huge.
Tue, Jan 18, 2011 at 1:32:55 PM | Exported AutoCAD file is too large
There is very little that we can do without knowing more about your project.   CAD files is your probable problem.
What is the sheet in question?  What kind of views?  Image files?
Does it have nested elements like details or detail components that have nested CAD files?
Tue, Jan 18, 2011 at 1:56:59 PM | Exported AutoCAD file is too large
SHANEBOLS1978
I exported a sheet with 3D and 2D views on the sheet.  I took the 3D views off of the sheet and exported and the file size was reduced to under 1 MB.  I solveed my own problem but I appreciate your help.
Tue, Jan 18, 2011 at 2:22:06 PM | Exported AutoCAD file is too large
When you export a 3D view, you are exporting the whole model in 3D.   Thus you had multiple models.
exporting to autocad
Fri, Aug 31, 2012 at 7:35:41 AM
Shared coordinate with AutoCAD Problem
Tue, Nov 30, 2010 at 9:09:10 AM
FILLED REGIONS EXPORTED TO AUTOCAD
Thu, Nov 6, 2008 at 4:45:16 PM
extracting hatch pattern from autocad file
Wed, Sep 21, 2011 at 4:01:20 PM
Exporting Revit to AutoCAD
Thu, Apr 12, 2012 at 9:56:53 AM
Page generation time: 1.7510
