Forums >> Revit Building >> Technical Support >> Cutting through a sweep
Mon, Jan 17, 2011 at 6:39:46 PM | Cutting through a sweep
cma6490
I designed a log cabin in revit. For the walls i used sweeps to make it look like logs in 3d view. When i went to 3d view it wont cut the sweeps to show the trim. it only cuts out to show the windows. I tried to design a component in place and make a void extrusion and cut it but it doesnt seem to cut the sweeps. If anyone could help that would be great.
Thanks
Tue, Jan 18, 2011 at 7:41:53 AM | Cutting through a sweep
Not clear :> "...When i went to 3d view it wont cut the sweeps to show the trim. it only cuts out to show the windows."
Sweeps added to walls only square cut at the wall ends so I don't like sweeps or reveals for these.  Check out this thread and see if this helps: http://www.revitcity.com/forums.php?action=viewthread&thread_id=17944
Otherwise, read some of the many posts ikn the forums searching with only the word -  log.
cutting through a sweep
Thu, May 18, 2006 at 10:57:25 AM
Cutting a Sweep - Brick Detail
Sun, Jan 4, 2015 at 3:37:41 PM
Solid Sweep Not Cutting in Section
Mon, Dec 18, 2006 at 2:06:34 PM
Vertical Wall Reveals not cutting sweep
Wed, Nov 8, 2006 at 9:23:11 AM
Cutting Solid Sweep?
Sun, Apr 23, 2006 at 11:03:51 AM
Page generation time: 0.1656
