Forums >> Revit Structure >> Technical Support >> Linking Arch file into Struct and using Arch groups?
Mon, Jan 17, 2011 at 2:34:50 PM | Linking Arch file into Struct and using Arch groups?
bizz3d
Is it posible to link an Architects Revit file and use its groups within my Structural Central file? I would like to frame up only the apartment units he created instead of the entire floor. Is this posible?
Mon, Jan 17, 2011 at 2:55:39 PM | Linking Arch file into Struct and using Arch groups?
How about copying the architects groups into your project same place?  Then rename this group to structural framing then edit the group removing the architectural elements and adding your own.  All the groups will be in the correct place and modified as you need them.
If he changes his group or relocates ... you will still have to alter yours.
Mon, Jan 17, 2011 at 6:18:07 PM | Linking Arch file into Struct and using Arch groups?
bizz3d
If the Architect updates? Do I reimport all the groups? What happens to my work that was applied to the imported groups before the update?
Tue, Jan 18, 2011 at 7:44:19 AM | Linking Arch file into Struct and using Arch groups?
As I posted: "If he changes his group or relocates ... you will still have to alter yours"  Your group is not his group so it will not move or change with his changes.
We have >2K cols in proj. How can we replace our arch. elements 4 struct. ones
Mon, Dec 12, 2011 at 4:05:12 AM
Combinng sheets from Revit Arch, Struct and MEP into one CD set
Mon, Apr 13, 2009 at 2:40:35 PM
Arch and stuct linked files are showing through Mech obejects in sections
Thu, Jun 16, 2011 at 8:02:43 AM
2D Arch file usful for Revit Struct?
Mon, Nov 8, 2010 at 11:23:09 AM
ARCH Model and STRUCT Model in the Same File
Mon, Jul 13, 2009 at 6:49:42 AM
Page generation time: 1.6767
