Forums >> Revit Building >> Technical Support >> Autocad MEP Import Transparent Materials
Mon, Jan 17, 2011 at 1:58:48 PM | Autocad MEP Import Transparent Materials
mlennon
Hi, I'm having trouble with an imported Autocad MEP 2007 .dwg file being transparent in all of my views. I'm using Revit 2011 with Windows 7 32 bit and ATI Radeon HD 3400 video. In object styles I would like to give specific imported layers materials/colors. Certain layers are working and others are not. For example, my ahu's show up with a solid color, but all ductwork looks wireframe.(See attached) Any ideas? This is the first time this has happened to me.
Thanks for your help,
Mon, Mar 21, 2011 at 11:18:59 PM | Autocad MEP Import Transparent Materials
mlennon
Hello, I'm still running into this problem importing AutoCad MEP files into my Revit MEP model. The Autocad model comes into revit looking like wireframe, even when in a shaded view. Do i need to modify to 3d solids (if in fact they are that)? Also, can i run an interference check with an imported autocad file in Revit?
Thanks,
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Autocad MEP imported into Revit MEP Pros/Cons
Fri, Jul 22, 2011 at 1:08:45 AM
Transparent dwg import
Mon, Apr 21, 2008 at 9:07:18 AM
Exporting from Revit 2013 to Autocad MEP 2010 while retaining intelligent object
Sat, Dec 7, 2013 at 12:08:38 AM
Inserting IFC into AutoCAD MEP
Tue, Feb 12, 2013 at 2:01:28 PM
Page generation time: 3.1244
