Forums >> Revit Systems >> Technical Support >> Pipe size
Mon, Jan 17, 2011 at 10:55:23 AM | Pipe size
maenhoudtbrecht
 hello,
i have 2 different pipe sizes in revit mep (lets call one type A and another B). I draw a simple pipe routing with pipes and elbows (all in type A). No i want to change the size. When i select a pipe and a elbow, i see both sizes (size A and B). when i only select a pipe or only an elbow i see only A sizes. Is this normal?
Becaus when i select multiple fittings i only want to see class A.
Thanks in advance
Fri, Jan 21, 2011 at 11:27:02 AM | Pipe size
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
where are you seeing the pipe sizes? on the options bar? or in the properties palette?
Try this...hoover over a piece of pipe hit tab once or a couple time so that all the connected piping and fittings are selected then left click to highlight them now on the options bar you should have multiple choices for the sizes.
This is all assuming you are using the correct pipe types and content...similiar that of OOTB content.
 hth
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
pipe tee size
Thu, Jun 7, 2018 at 3:50:08 PM
Revit2013 - 'Pipe Size' Parameter Can't Be Used
Mon, Jun 10, 2013 at 2:25:34 PM
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:45 AM
Pipe Branch Takeoff/Gain
Fri, Feb 26, 2016 at 12:29:37 PM
Revit MEP 2012 - Transfer Pipe Size & Pipe Materials bug?
Fri, May 18, 2012 at 10:04:27 AM
Page generation time: 0.2190
