16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Dimensions in feet and meters
33 Posts No Rating |
I have a client who wants to see building dimensions in feet and centimeters and areas in feet and meters. Is there is simple optioon or was of doing this in Revit? I am using Revit 2011? Thanks
You can use two dimension styles, one metric and one english, then add both dimensions.
Thanks. What about for shoowing the room areas in both meters and feet - is there a similar solution?
Edit your room tag and look at the unit options under the area portion of the tag.
Level Display (only) to decimal feet |
Sun, Aug 10, 2014 at 11:00:01 PM
12
Revit 2014 - Need to eliminate zero feet in dimensions |
Thu, Apr 3, 2014 at 1:07:01 PM
Feet per second squared error? What?? [ 1 2 ] |
Wed, Feb 20, 2013 at 2:26:22 AM
18
Toposurface Contours |
Mon, Aug 25, 2008 at 4:47:22 PM
Face to face wall dimensions |
Mon, Jul 11, 2011 at 11:13:34 AM
