Forums >> Community >> Newbies >> Is there a typical residential (wood framing) wall family?
Sat, Jan 15, 2011 at 1:54:52 PM | Is there a typical residential (wood framing) wall family?
GeneLaratonda
GeneLaratonda Avatar
I took a break from the tutorials to recreate a 3 bedroom farmhouse plan that I downloaded from the LSU AgCenter.
I noticed that the walls are metal studs by default in Revit. Without having to duplicate and editing a type, is there a family of wood framing partitions that I can load? When I click on "Wall" the "Load Family" option is not available.
Sun, Jan 16, 2011 at 10:28:02 AM | Is there a typical residential (wood framing) wall family?
In Revit walls, the core layers are a material and thickness only definition.  The core elements temselves are really not modeled.  So the difference between metal stud and wood stud is only a name/thickness change and how it is represented in cut profile hatch patterns.  Studs themselves are not modeled.
So to create your wood stud wall, edit the type giving it a new ttpe name, modify the layer(s) thicknes amd material assignments and you have your wood stud wall.
Sun, Jan 16, 2011 at 1:02:47 PM | GeneLaratonda
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting GeneLaratonda from 2011-01-15 13:54:52
Click Attached File
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wood Framing Walls Extension; Locating and External framing
Fri, Jul 31, 2015 at 8:03:14 PM
wood framing extension
Mon, May 7, 2012 at 3:23:48 PM
wood framing wall extension
Tue, Aug 16, 2011 at 4:13:20 PM
Wood Framing - add top & bottom plates to wall family?
Mon, Jan 19, 2009 at 12:22:00 AM
Residential Wall Types
Sun, Mar 21, 2010 at 11:30:11 AM
Page generation time: 0.9595
