Forums >> Revit Building >> Technical Support >> Thickness of created forms in Family/Conc Mass Editor
Sat, Jan 15, 2011 at 11:26:09 AM | Thickness of created forms in Family/Conc Mass Editor
proooo
hello,
i have problems defining a thickness from a form i have created thru the magic button in "family editor"/"conceptual mass editor" mode of revit architecture 2011.
also to basically create the form is hardship.
my suggestion for a new public floor in a site at palermo, italy - seem to create great challenges for the model generator inside revit, several of my tries have only delivered the sad message "unable to create form".
this is how i tried making it (see attached pix). with 3d polylines arranged parallell in plan and individually deviations in z-axis/height that together form a wavy surface i imagine should be construced from concrete shells.
i want to have the thickness up to 400 millimeters - but it does not seem possible..
2 questions:
- how to define or obtain a certain thickness on forms created thru the "create form"-button in revit conceptual mass editor?
- what are the limits of complexity on the modelling engine inside revit, should i learn myselves rhino/3ds max?
yours,
harald
87506_3d_with_no_neighb6.jpg87506_3D9.jpg87506_render_final.jpg87506_sanaa-3-rolex-learning-center-epfl-sanaa-copy-hisao-suzuki-1-11099.jpg
Architect student - twitter.com/proooo @
The Bergen School of Architecture, Bergen - Norway
www.bergenarkitektskole.no
Tue, Feb 1, 2011 at 1:41:25 PM | Thickness of created forms in Family/Conc Mass Editor
DeifyMe
4 Stars: 2 Votes
I think what you need to do is import your model into a project as a mass family
-then under "Massing & Site" go to "Model by Face" and click on "Roof"
-setup your roof construction which will give it it's thickness
-select the mass
-click on "Create Roof" on the tool bar and there you go. I've created a roof that is 3" thick in the attached image. I did find that any thicker that I received an error "can't make roof". Not sure what that is about.
adding mass in family editor or in place family creation
Thu, Nov 23, 2006 at 9:52:52 AM
Family Editor: works... then doesn't!
Fri, Sep 2, 2005 at 5:23:05 PM
hosting object to reference point in mass family editor
Fri, Apr 4, 2014 at 1:45:49 PM
'forms' not available in 'in place mass' or components.please help
Fri, Aug 30, 2013 at 3:20:58 AM
Saving a family fom project to family editor
Fri, Sep 17, 2004 at 6:39:40 PM
Page generation time: 0.7532
