Forums >> Community >> The Studio >> revit plugins
Thu, Nov 3, 2005 at 2:34:01 PM | revit plugins
Thread Post Kudo! #1
siman406
4.5 Stars: 4 Votes
do you guys know if there is any plugins for revit that allow for more realistic quality renders.... similar to the way vray and maxwell work with viz/max. i am trying to do more work in revit but the quality of renderings is no where near viz or max.... any suggestions? Thanks silas
Thu, Nov 3, 2005 at 3:05:13 PM | RE: revit plugins
TomDorner
4.5 Stars: 25 Votes
Use Viz or Max. Revit 8.1 will export to DWG with materials. See Viz or Max help files. Tom
Fri, Nov 11, 2005 at 8:46:51 PM | RE: revit plugins
winn
hi tomm i tried exporting a revit model to viz 2006,but the scale applied on the materials gets distorted. could you tell me where i could get an arpc plugin for viz 2006?
Sat, Nov 12, 2005 at 9:33:16 AM | RE: revit plugins
TomDorner
4.5 Stars: 25 Votes
No "plug-ins" in the Revit world. If you modeled your building correctly all the material meta-data simply goes into Viz2006 from Revit via the DWG export process. Be sure you export out of Revit from a 3D view at full size. Link the model into Viz and in Viz you will need to remap the materials of the Revit model to Viz materials. The DWG knows that a certain layer is defined to have a material "Brick - red", but then you need to tell Viz what map to use for Brick-red. Any material scaling problems are a problems inside of Viz not related to Revit. Tom
Recommended Revit PLugins, curse-ons, or Extensions
Tue, Sep 3, 2019 at 5:47:17 AM
Thea Render Plugin - anyone interested in developing one?
Thu, Feb 21, 2013 at 7:59:55 AM
http://www.maxwellrender.com/forum/viewtopic.php?t=273
Mon, Mar 28, 2005 at 9:08:01 PM
Twinmotion - REVIT Plugins update V2.0.6.0
Fri, Jan 15, 2016 at 8:45:20 AM
Addin: Projects used with previous version of plugins not compatible.
Sat, Apr 13, 2013 at 4:38:33 AM
Page generation time: 1.5312
