11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Default Pahse Filter for New Views
148 Posts No Rating |
Greetings. Regarding Phase Filters, is there a way to change the default phase filter for a new view? Every new view begins as 'Show All'. Our office would prefer to have each new vew begin as 'Show Complete'. I realize that I cannot modify Show All. Even if I can modify Show All, I'd prefer to keep it as it is, for those who understand it and wish to use it. I also realize that I can use View Templates to manage views once they are created ... but many users are getting confused with red infills (at new doors in existing walls) and grey'd out (existing) walls. To avoid this confusion and to ease my bosses concerns, I am hoping to set the default for ALL new views to Show Complete. Can this be done?
Ian Shafer
Principal Consultant
True North S&F Consultants |
It's a little bit of like going around you elbow, and then behind your head and through your legs to get to your nose, but give this a shot: http://screencast.com/t/xBHco3EW
Edited on: Fri, Jan 14, 2011 at 4:55:04 PM
Carl. So if i understood correctly, if I create a new plan view and immediately set the Phase Filter to Show Complete, the next plan view I create will have Show Complete as the default view? If so, I assume that I'll need to do this for each (family) type of view ... What I didn't get (and probably 'cuz it's friday at 5:3 .... what was the purpose of creating the view template?
Ian Shafer
Creating the view template allows you to check that little box that says "Use this view template as default for new views of this type that are created" which means that every time you make a new plan, that view template is going to be used, including the default phase settings. Cheers!
ahh ,,, they brilliance shines through. Many thanks.
Ian Shafer
Keynotes filter by sheet and default graphics |
Mon, Jan 8, 2018 at 3:40:58 PM
Hide unreferenced views |
Wed, Dec 28, 2011 at 5:48:18 PM
Seperating layers hatch with filter |
Wed, Feb 12, 2014 at 3:15:30 AM
Filter views on a sheet by revision |
Tue, Jun 2, 2015 at 4:06:28 PM
create a filter for floor surface patterns below |
Mon, Dec 3, 2018 at 6:51:01 AM
