12 Users Online (10 Members):
Forums >> Revit Systems >> Technical Support >> Type label question
I want to add a "Title" parameter to my "Graphic Scale" family and I want it to change the text whenever I change the scale. I added a text type label and went through each type and added the text for each type. Whenever I change the type while editing the family the value does change. However, when I try insert one on my title sheet it stays at whatever type I had it set to when I loaded it. Why doesn't Revit remember what my text type parameters are when it remembers my dimension type parameters? I know I could do simple text with visibility linked to the yes/no parameter for the visibility of each graphic type, but I consider that a poor workaround for something that should be simple.
Nevermind, it's working now.
Revit API - Create new Family Label Type |
Sat, Aug 18, 2012 at 11:14:13 PM
Section Heads label displays dashes rather than a label |
Thu, Oct 12, 2017 at 1:01:46 AM
Partially Underline Text in a Label? |
Tue, Jul 24, 2012 at 3:11:11 PM
parametric window should recognize wall type! |
Tue, Apr 11, 2006 at 1:32:44 AM
New Title Page Label Using Project Information |
Sat, Feb 10, 2018 at 11:54:48 AM
