12 Users Online (10 Members):
Forums >> General Discussion >> Wishlist >> Wishlist - Floor fills
21 Posts No Rating |
Hey how's this? When it comes to adding fills to rooms, instead of spliting the slab and all that nonsense... what if when adding a room (RM), you had a perameter under properties> identity data> where you could just assign a fill? The extents of that room (no matter how large or complex) would constrain the exents of the fill, be filled instantaniously and would never need manual updating when walls move. Like?
You can already do a thin floor that is your finish and lock the sketches to the walls. But ... maybe your idea could be expanded on by autodesk. Where you can assign a finish to room surfaces, associated to the rooms and displayed accordingly. As such those surfaces would all schedule and could be quantified.
The issue is... what if I have more than 1 material in the same room. Does it still work for this kind of feature?
Of course - unique settings would require an over-ride of some sort....and that would get complicated.
yeah i think the whole process of sketching thin slabs or spliting slabs is clunky and time consuming (sorta feels like a work around, rather than the intended procedure)... of course the idea would have to be expanded on. Ultimately i would like to see a paintbucket style feature, where by you just select a fill> click and fill, photoshop/sketchup/archicad style but that just too easy, autodesk wouldnt go for it.
Export fills to layers |
Fri, Sep 11, 2009 at 11:51:47 PM
Color fills |
Thu, Aug 31, 2006 at 11:10:03 AM
Floor colour fills or different floors? |
Wed, Apr 19, 2006 at 5:06:53 AM
EXPORTING TO AUTOCAD- WITH NO COLOR FILLS |
Sat, Mar 31, 2018 at 3:07:56 AM
Wishlist |
Workflow & Implementation >> Chameleon
Wed, Apr 24, 2024 at 12:22:03 PM
