Forums >> Revit Building >> Technical Support >> Revit to DWG
Thu, Jan 13, 2011 at 1:21:49 PM | Revit to DWG
gdoherty0102
3 Stars: 2 Votes
When I am exporting to DWG the text gets huge, dimensions get huge, and overidden dimensions get altered.  What do I need to do to make Revit export how I see to DWG?  I tried to take to PDF then to DWG, but the conversion program I used for this did not work very well.  Any suggestions?
Thu, Jan 13, 2011 at 3:58:33 PM | Revit to DWG
rkitect
rkitect Avatar
4 Stars: 29 Votes
Don't export to DWG?
 Is this because the deliverable requires a DWG or because of outdated consultants? My best advice is to label it in AutoCAD (or whatever you're DWGing in) since annotations between Revit and DWG are a known issue.
Thu, Jan 13, 2011 at 6:00:34 PM | Revit to DWG
gdoherty0102
3 Stars: 2 Votes
It is for the Forestry Department and they require DWGs.
Thu, Jan 13, 2011 at 8:25:19 PM | Revit to DWG
rkitect
rkitect Avatar
4 Stars: 29 Votes
Yeah, I kinda figured that was the case. As such I my only recommendation is to annotate in Autocad.
How are the notes showing up? In paper space? Model Space? Are you exporting bound or xrefd?
Fri, Jan 14, 2011 at 8:20:42 AM | Revit to DWG
We export to DWG all the time and do not have your problems.  I suggest you look at the translation settup.  Something is wrong there.
Fri, Jan 14, 2011 at 8:43:02 AM | Revit to DWG
rkitect
rkitect Avatar
4 Stars: 29 Votes
I have never seen a setting for annotation sizes in the translation setup. Perhaps this is a font issue? What type of font are you using?
Fri, Jan 14, 2011 at 11:56:25 AM | Revit to DWG
rkitect
rkitect Avatar
4 Stars: 29 Votes
Take a look at the last post in this thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=22996
Let us know if you ahve the same result.
Exporting views with DWG bocks to dwg.
Sun, May 21, 2006 at 8:36:59 PM
Solution 2D DWG to REVIT Pls
Sun, Jun 18, 2006 at 6:04:13 AM
DWG and revit preformance
Mon, May 15, 2017 at 2:24:05 AM
Revit to DWG in one single flie.
Mon, Sep 22, 2014 at 4:01:47 PM
Revit 2009 Add Levels to Dwg
Mon, Sep 19, 2011 at 3:15:16 PM
Page generation time: 5.3301
