26 Users Online (24 Members):
Forums >> Revit Systems >> Technical Support >> Calculating Pipe Sizes
1 Posts No Rating |
Any tips on letting Revit automatically calculate pipe sizes?? Trying to get from fixture units, to flow rate and or velocity for plumbing pipe. Has anyone had success with it? Ethan
ASSUMING that all the elements were corectly modeled, if you do the following it should autoadjust the pipe/duct to the correct size based on the equipment you are coming from. - Place equipment in project.
- Select pipe/duct tool.
- Start pipe/duct AT connectino (you snap to the little target symbol on the equipment).
- Before placing the next point, hit the space bar.
- Voila! Auto sized piping/ducting!
- PROFIT!!!!
HTH,
Pipe sizing in Revit. |
Tue, May 6, 2014 at 7:00:56 AM
Revit 2012 MEP pipe sizes |
Tue, Mar 6, 2012 at 2:13:57 PM
Revit MEP Custom User Pipe Sizes Not Available When Drawing Pipes |
Sun, Dec 18, 2016 at 8:51:17 PM
Revit MEP 2012 - Transfer Pipe Size & Pipe Materials bug? |
Fri, May 18, 2012 at 10:04:27 AM
Pipe Sizes |
Thu, Jan 22, 2009 at 5:56:11 PM
