7 Users Online (5 Members):
Forums >> Revit Building >> Technical Support >> wall joins with a linked file.
Hello; I have two files. One is host, the other is link. The link file contains structural model like columns, beams, floors and structural walls. The host file contains all the other data. My problem is that i cannot join the walls with the structural walls because the structural walls are in the link. Is there a way to join normal walls to the linked structural walls? I got two solutions: 1. To use in place void extrusions to cut the geometry from the normal walls. 2. To create a junk workset and create little structural walls and join walls to them, then close this workset so these structural walls are invisible. But I want a third solution that doesn't involve above solutions.
Try - copy/monitor the structural walls and turn the structural walls off..... And I would put those on a seperate workset.
Thanks a lot. You made my life a lot of easier
Wall joins in linked files |
Mon, Aug 19, 2013 at 2:58:42 PM
WALL JOINS BETWEEN LINKED rvt FILES, IMPOSSIBLE??? |
Wed, Aug 15, 2007 at 12:23:06 PM
Does anyone else wish that there was a toggle to make wall joins the default off |
Wed, Aug 19, 2009 at 9:49:42 AM
Can you make wall joins Miter by Default? |
Wed, Dec 21, 2016 at 1:52:44 PM
14
I hate the Revit Automatic Wall joins |
Thu, Oct 25, 2007 at 9:59:44 AM
