Forums >> Revit Building >> Technical Support >> Conditional statemnent for negative value of degree celcius not working
Thu, Jan 13, 2011 at 1:31:39 AM | Conditional statemnent for negative value of degree celcius not working
bhavana
4 Stars: 1 Votes
Hello,
one conditional statemnt if temperature = -10 degree celcius then
Statement if(Temperature = -10 degree celcius), 100 mm , 200 mm) always giving me the 200mm
 if temperature = -10  the answer should be 100 mm
Please suggest me
Thu, Jan 13, 2011 at 8:12:32 AM | Conditional statemnent for negative value of degree celcius not working
I believe you are having a units problem.
Sun, Jan 16, 2011 at 11:01:10 PM | Conditional statemnent for negative value of degree celcius not working
bhavana
4 Stars: 1 Votes
Hi,
 can we do not use different units  ( like degree celcius and mm ) in one  aonditional statement?
Plesae suggest me?
Thanks
Arch 2012 Conditional Formatting
Tue, Sep 18, 2012 at 11:08:38 AM
how to type degree symbol in text
Mon, May 21, 2007 at 11:54:29 AM
Conditional statement
Thu, Jun 27, 2013 at 9:58:47 AM
negative extrusion
Mon, Apr 10, 2017 at 8:13:59 PM
Conditional Syntax not working!!!
Mon, Feb 26, 2007 at 9:02:48 AM
Page generation time: 0.2318
