Forums >> Revit Building >> Technical Support >> Coordinating with consultants
Thu, Jan 13, 2011 at 12:04:19 AM | Coordinating with consultants
ROBDEVEYRA
Hi- Whats the most efficient way to send out a Revit File to consultants - complete with Linked Revit Models, Linked Cad, number keynotes etc.??
Thanks in advance.
Thu, Jan 13, 2011 at 8:34:16 AM | Coordinating with consultants
You should read the similar threads below:  \/
We use FTP  on our server.  You can read more about that if you search the forums using FTP.
Thu, Jan 13, 2011 at 3:26:52 PM | Coordinating with consultants
ROBDEVEYRA
Thanks so much...I appeciate all the help.
Is there a way to e-transmit my File with all it's linked files (RVT & DWG) thats attached to it.
Thanks yet again.
Thu, Jan 13, 2011 at 3:37:47 PM | Coordinating with consultants
Revit only combines the files on the viewing machine so you can not transmit them as one file.  They are independent files and their pathing has to be set in such a manner that when the revit file is opened, it can find the linked files.
Tue, Jan 18, 2011 at 1:43:06 PM | Coordinating with consultants
ROBDEVEYRA
Thank you very much for this info.
Would it be best to put Main File and the Linked files in a folder instead?. I'll link them all from within the folder. This way I could just send them the entire folder. Would this be a good way of doing it?
Working with Consultants
Tue, Sep 28, 2010 at 9:29:57 PM
Finding Consultants who use Revit
Thu, Mar 10, 2016 at 1:45:54 PM
Limit Revit Access to certain consultants within Collaboration for Revit
Fri, Jun 1, 2018 at 2:50:05 PM
Work with Consultants Workflow
Sun, Jan 28, 2018 at 6:03:06 PM
Searching for consultants to use Revit
Wed, Jun 23, 2010 at 4:47:51 AM
Page generation time: 0.0615
