Forums >> Revit Building >> Technical Support >> Yes/No Parameter when checked in Grey
Wed, Jan 12, 2011 at 2:18:56 PM | Yes/No Parameter when checked in Grey
xixiha
One thing has confused me for a long time.
 When we set up a yes/no question, by default it comes as grey checked. We can uncheck it or check it again. But it's no longer grey. Any difference here?
Wed, Jan 12, 2011 at 2:31:56 PM | Yes/No Parameter when checked in Grey
pchan
pchan Avatar
5 Stars: 5 Votes
Are you talking about the parameter from family editor? if so, most likely you won't see the effect until you load the amily into the project.
Wed, Jan 12, 2011 at 3:05:52 PM | Yes/No Parameter when checked in Grey
xixiha
I am talking about a project parameter I added in the central project file.
Wed, Jan 12, 2011 at 3:19:18 PM | Yes/No Parameter when checked in Grey
pchan
pchan Avatar
5 Stars: 5 Votes
What are you using it for in the project?
when the checkbox is grey, i guess you have selected more than one elements, then it will be in grey, (in other words, there are some things that are checked "yes" and some are "no"Winking but once you check the box again, you are overwriting all the element.
hope that explains your situation
Wed, Jan 12, 2011 at 3:37:33 PM | Yes/No Parameter when checked in Grey
xixiha
all yes/no parameter created for a project parameter come as this way. You can have a try and you will see what I mean. I didn't select mutiple things.
Wed, Jan 12, 2011 at 3:59:56 PM | Yes/No Parameter when checked in Grey
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
usually when this happens it means you have multiple elements assigned to that yes/no paramter and some are checked and some or not checked.  so it does not know what to give you except a grey check box.  if you change the grey check box to blak check you have turned on all the elements that where off (sharing that parameter) if you uncheck the box completly you will turn off all the elements.
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Wed, Jan 12, 2011 at 4:10:46 PM | Yes/No Parameter when checked in Grey
xixiha
I reiterate this, I am not selecting anything, just in a view, and I add a yes/no parameter to all the views. It comes as grey.
see attachment
Wed, Jan 12, 2011 at 4:27:41 PM | Yes/No Parameter when checked in Grey
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
Then I guess it is in a state of limbo, The box does not know weather it is (yes or no) til you tell it.
 I didn't read all the threads, my mistake.
I gave it a try and mine is grey too.  This is the only conclusion I can come up with is the "limbo" state.  When you assign a Yes/No paramter to something say a wall, do all walls take the yes or the no? or is it waiting for you to tell it one way or the other?
The grey is an obviouse way of saying "hey, you havn't addressed me yet, Am I yes or no?"  and yes is the default.
Wed, Jan 12, 2011 at 4:44:35 PM | Yes/No Parameter when checked in Grey
pchan
pchan Avatar
5 Stars: 5 Votes
ok i agree with cadman, when you first set  up this project parameter, by default, they are grey since nothing has been assigned yet, so you have to phyically un-check the checkbox, check it again to determine what you want for that "view" so the grey color means it is a undetermined state to my understanding.
If/Then & Yes/No Parameter Condition
Fri, Aug 29, 2014 at 2:18:54 PM
Objects/Components render GREY?! :(
Mon, Jun 23, 2014 at 2:22:22 PM
Hide Instance Parameter ruled by formulas from the Property Palette
Thu, Nov 21, 2019 at 11:26:43 AM
Can a Yes/No Parameter control a Length Parameter?
Thu, Mar 22, 2012 at 12:17:27 AM
Why is my default 3D model all grey?
Thu, Jan 5, 2012 at 7:22:09 AM
Page generation time: 3.9691
