Forums >> Revit Building >> Tips & Tricks >> Autocad details to Revit
Thu, Nov 3, 2005 at 12:17:43 PM | Autocad details to Revit
nedbag
I wanted to get an idea of how best I can transfer all my standard details in Autocad to Revit.
Thu, Nov 3, 2005 at 6:25:49 PM | RE: Autocad details to Revit
Rythmick
5 Stars: 2 Votes
Create Drafting Views to import or link them onto. Drafting views are non model related 2d drawings that you can place on sheets like other views. For ones you will use often you can create and import the details into drafting views in your project template file and they will be available in all your new drawings without having to import every time. This quote from Mr. Spot is relevant also. "Once we have a detail that we want, we group it and rename it appropriately. Then load it into a special detail project where we can grab details from as required. This way we can view the details, select the ones we want and copy and paste into the new project." Post edited on 2005-11-03 18:42:21
Autocad details linked into Revit
Mon, Jun 6, 2016 at 1:54:23 PM
Importing Autocad to Revit, adding details and notes, then back out to Autocad
Thu, Feb 18, 2010 at 8:57:44 PM
LInked AutoCAD details into Revit 2009 workset project
Tue, Jun 28, 2011 at 5:07:32 PM
Autocad details with hatch showing as black/solid
Wed, May 22, 2013 at 11:47:29 AM
Details from Cad to Revit
Wed, Jan 31, 2007 at 1:04:11 PM
Page generation time: 1.8412
