Forums >> Community >> Newbies >> How do you center a cased opening in a wall?
Wed, Jan 12, 2011 at 12:02:55 AM | How do you center a cased opening in a wall?
GeneLaratonda
GeneLaratonda Avatar
I'm just trying to work through the Autodesk Revit Architecture 2011: No Experience Required book by Eric Wing and am having problems with something pretty basic from what I'm reading around here.  :o
If anyone has the book it's on page 195. In Figure 4.52 the bottom right-hand quadrant of four rooms has cased openings between them. When I go to place the cased opening as a component the temporary dimensions do everything but centerline of the opening to the center point of a length of wall. I thought a triangle was supposed to show up, but nooooo. I tried the align tool and was able to select the center of the cased opening, but there was no reference line to mark the center point of the length of wall.
That's a real bummer when I have soooo much more to learn and am getting stuck on this.
Thanks,
Gene
Wed, Jan 12, 2011 at 7:47:14 AM | How do you center a cased opening in a wall?
coreed
coreed Avatar
4 Stars: 16 Votes
you will find in Revit that even though a continuous wall is broken, Revit still treats the wall as continuous segment when placing objects in that wall.
Edited on: Wed, Jan 12, 2011 at 12:22:48 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jan 12, 2011 at 11:24:05 AM | How do you center a cased opening in a wall?
GeneLaratonda
So, the least complicated way to do this would be to do a little math (length of wall minus opening size, divided by two), use a temporary dimension, and place it by the side of the opening in the length of wall?
...or use the offset tool with a reference line at that same number.
Edited on: Wed, Jan 12, 2011 at 1:39:56 PM
Wed, Jan 12, 2011 at 12:16:51 PM | How do you center a cased opening in a wall?
No, the easiest way to locate your opening is to quicky add a dimension from wall to opening center to wall then click on the EQ and delete the dimension.
Wed, Jan 12, 2011 at 1:49:38 PM | WWHub
GeneLaratonda
Quoting WWHub from 2011-01-12 12:16:51
"No, the easiest way to locate your opening is to quicky add a dimension from wall to opening center to wall then click on the EQ and delete the dimension."
That did it!
 As a newbie to Revit I'm going through the book I mentioned. After that I was going to go through a bunch of videos on YouTube created by Autodesk Student Experts TU Graz from Austria. After that I was going to dive into the Mastering book that is the official guide.
Do yinz think I could be ready for the certification by then or are there other resources you recommend?
Thanks,
Gene
 ps Did you hear? Pittsburgh's goin' to the Super Bowl.  ;o)
Edited on: Wed, Jan 12, 2011 at 4:23:02 PM
Demo door, make cased opening, no fill in wall
Fri, Mar 23, 2012 at 12:34:24 PM
Center an opening in the wall
Sun, Jul 26, 2009 at 6:36:13 PM
how do I load cased opening and arched openings
Wed, Sep 28, 2011 at 3:05:58 PM
Openings
Thu, Jan 28, 2016 at 10:57:11 AM
Wall opening family in slanted wall
Thu, Sep 6, 2012 at 2:50:57 PM
Page generation time: 1.0093
