Forums >> Revit Building >> Technical Support >> Converting to vector based file types
Thu, Nov 3, 2005 at 11:27:31 AM | Converting to vector based file types
SixMyles
I've done some searching through the forum and can't seem to turn up anything for my problem. How is everyone exporting their Revit perspectives to a vector based program such as Illustrator. I've tried using AutoCAD as a mediator and can't AutoCAD to print the view correctly. Is there a way to save a perspective as a .pdf, .eps or other vector based file? Thanks for the help, Myles
Thu, Nov 3, 2005 at 5:10:01 PM | RE: Converting to vector based file types
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use a PDF printer such as: Adobe Acrobat Professional CutePDF Jaws PDF PDF Factory To name a few. You can also export any view out as a image...
Sat, Mar 31, 2007 at 8:42:02 PM | Converting to vector based file types
dRad
I haven't yet figured out how to export a revit 3d view as an image and have it come out vector based.  They only seem to come out as rasters which are virtually useless in illustrator.  As far as the print via pdf option, the image can be opened in illustrator as a vector.  It is not a line drawing however, rather a grid of smaller images.  This is also pretty useless when trying to manipulate the image in illustrator.  Any other suggestions for exporting as a vector line drawing?
Print vector based WITH shading
Fri, May 4, 2012 at 3:25:40 PM
Revit to CorelDraw
Tue, Jan 31, 2012 at 5:43:14 PM
vector vs. raster(revit2008)
Wed, Mar 22, 2017 at 5:51:15 AM
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:37 PM
converting files for use between cad programs
Thu, Apr 30, 2009 at 12:39:03 AM
Page generation time: 2.1051
