11 Users Online (9 Members):
Forums >> Revit Structure >> Tips & Tricks >> Column Location Marks
3 Posts No Rating |
I have drawn a Wide Flange column starting at -1'-0" base going up 9'. I added a 18"x18" concrete column below it (acting like a pier) with a base offset of -4' up to -1'. When the pier is located with its top at -1', the column location mark shows up as the grid intersection. However if I move the top of the pier to -1'-6", the column location mark is now blank. Has anyone run into this issue or knows a fix?
Your grids no longer intersect the column. In elevations, pick your grids - make sure the switch is set to 3D - then drag them down.
3 Posts No Rating |
such a simple fix. Thanks for the help. It was driving me nuts.
Graphical Column Schedules problem.... |
Wed, Sep 9, 2015 at 12:41:56 PM
Column Schedule |
Mon, Apr 21, 2008 at 7:35:29 AM
Graphical Column Schedule Categorized by Type Marks |
Wed, Jul 22, 2009 at 11:56:06 AM
Column Location |
Mon, Jun 27, 2011 at 11:52:28 AM
Column Join issue |
Wed, Oct 11, 2017 at 10:10:15 PM
