Forums >> Revit Building >> Technical Support >> Applying woodwork walls
Tue, Jan 11, 2011 at 9:22:46 AM | Applying woodwork walls
davet
Could anybody tell me how I can apply skirting boards manually to internal walls. I've tried creating wall sweeps with them but I end up with so many different walls that I get lost as I'm building multi storey buldings. I'd like to be able to manually add skirting boards hopefully saving alot of hassel.
Could anyone assist??
Tue, Jan 11, 2011 at 10:53:23 AM | Applying woodwork walls
pchan
pchan Avatar
5 Stars: 5 Votes
You can do it  as wall host sweep.
Tue, Jan 11, 2011 at 11:29:45 AM | Applying woodwork walls
What pchan is saying is don't include the sweep in your wall definition - instead, model it in place.
Wed, Jan 12, 2011 at 1:46:33 AM | Applying woodwork walls
davet
Thanks guys.
Applying skirting boards to walls
Fri, May 20, 2011 at 7:18:42 AM
Applying Wall Finish and Scheduling It?
Fri, Jun 14, 2013 at 7:19:13 AM
Massing - Applying Materials to Imported Geometry from Rhino-HELP!
Sat, Dec 10, 2011 at 6:30:09 AM
Problem when applying a footing to wall
Thu, Aug 23, 2012 at 1:58:50 PM
walls with 2 hatches solid/pattern
Thu, Aug 23, 2012 at 7:27:21 AM
Page generation time: 0.5022
