Forums >> Revit Building >> Technical Support >> How to have glass facade with black framing after it is rendered?
Mon, Jan 10, 2011 at 11:02:29 AM | How to have glass facade with black framing after it is rendered?
Pepinho
Sorry, I should have asked this with my other question I posted. This is the only other thing that I need to know for my building. Some parts of my building use a glass facade but I need it to have black framing, when I render it - it is just a clear glass, I have had a bit of a play around with it but cannot seem to find where the black framing may be. Any help with this anyone?
Wed, Jan 12, 2011 at 7:00:07 AM | How to have glass facade with black framing after it is rendered?
KMunkholm
Hi Pepinho.
I´m not 100% sure that I understand your question - But assuming that your "glass facade" is a Curtain Wall (CW), and by "framing", you actually mean Mullions ?
  1. Pick the CW you allready created
  2. Edit/Duplicate to create a new type (and give it a new name - i.e. "CW with Mullions"Winking
  3. In the Type Properties dialouge, add "Vertical Mullions" and "Horizontal Mullions" as desired (In the OOTB template, there´s a "Rectangular Mullion: 50 x 150 mm" which is good for most)
  4. Also in the Type Properties, you´ll want to set "Grid Patterns" and "Join Conditions"
  5. Finish editing
  6. Pick one of the Mullions on the new CW (Use Mouse over/TAB to select)
  7. Chose Edit Type, and set the material to whatever black material you need (or create a new material)
Hope that helps, and good luck.
-Munkholm
www.revitforum.org
Glass keeps rendering black not transparent
Mon, Jan 23, 2006 at 4:01:41 AM
glass appears black when rendering
Thu, Feb 16, 2006 at 5:36:21 PM
my renders stays with black svreen
Fri, Jul 18, 2008 at 5:33:13 AM
Multi-Layered Sliding Curtain Wall With Glass + Fabric Curtains
Mon, Jan 4, 2016 at 9:41:21 AM
Trimming Wall Layers
Wed, Jan 3, 2018 at 8:47:20 AM
Page generation time: 2.4228
