Forums >> Revit Building >> Technical Support >> Circular Stairs
Thu, Nov 3, 2005 at 11:04:03 AM | Circular Stairs
jplitt
Does anyone know how to make circular stairs?
Thu, Nov 3, 2005 at 5:13:20 PM | RE: Circular Stairs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I assume you are referring to a spiral stair or alike? They are created exactly the same as any other stair by drawing the risers and boundaries. Note: The stair sketch cannot overlap itself with relyable results. If the stair sketch turns more than 360º you will need to split it into two stairs. HTH.
circular stairs
Mon, Mar 24, 2008 at 4:40:37 PM
attachig walls to circular stairs
Wed, Feb 13, 2013 at 4:17:33 AM
circular stairs with spiraling wall around them
Tue, Mar 24, 2009 at 3:58:27 PM
circular stairs
Wed, Mar 16, 2005 at 10:02:03 AM
Circular Arch
Tue, Jul 21, 2015 at 9:06:15 AM
Page generation time: 0.0673
