Forums >> Revit Systems >> Technical Support >> REVIT MEP 2011 - Duct union/TDF/TDC 35mm Frames
Mon, Jan 10, 2011 at 4:30:56 AM | REVIT MEP 2011 - Duct union/TDF/TDC 35mm Frames
CWCwtr7621
Somebody must have done this, or at least help out creating one. I'm a shop detailer creating a new union, showing a 35mm Frame, as a connector/Union modified to be able to connect to all internal insulation thickness,, ie 25 to 100mm. Also having the option to recess the frames.
Attached is my VAV with a TDF frame with some holes, but needs to be variable. I went about this wrong i think.
Anyone help?
Sun, Sep 2, 2012 at 5:15:18 PM | REVIT MEP 2011 - Duct union/TDF/TDC 35mm Frames
Mattmoot
I'm surprised no one has answered this post. We too are having a similar problem. Can't seem to find a way to get recess frames working properly.
Edited on: Sun, Sep 2, 2012 at 5:15:56 PM
Autocad MEP duct work question
Thu, Feb 17, 2011 at 11:12:01 AM
Duct won't tap to oval duct.
Tue, Aug 22, 2017 at 12:38:49 AM
Revit MEP 2011 sloping ductwork by default?
Thu, Nov 17, 2011 at 3:49:26 PM
Revit MEP 2011 crashes when circuiting electrical devices.
Thu, Jan 27, 2011 at 9:27:58 AM
Duct Systems.
Mon, Aug 5, 2013 at 7:48:16 AM
Page generation time: 1.6912
