Forums >> Revit Systems >> Technical Support >> Importing an inventor file into revit mep
Mon, Jan 10, 2011 at 3:56:20 AM | Importing an inventor file into revit mep
simmo1
How do you import a inventor 2011 into revit mep 2011
Many Thanks
Simmo
Thu, Jan 20, 2011 at 12:28:08 PM | Importing an inventor file into revit mep
MADnes
YES, SAVE YOUR INVENTOR FILE AS A SAT FILE TYPE. HERE IS A LINK THAT SHOULD BE HELPFUL. SKIP DOWN PAST HOW HE CREATED THE INVENTOR ELEMENT DOWN TO RIGHT BEFORE THE "BRING CONTENT INTO REVIT" HEADING.
Gabriel Flores AAS/CDD, BS/CM
Thu, Jan 20, 2011 at 12:28:41 PM | Importing an inventor file into revit mep
MADnes
SORRY HERE IS THE LINK I MENTIONED ABOVE.
http://www.aecbytes.com/tipsandtricks/2008/issue35-revit_inventor.html
Thu, Jan 20, 2011 at 2:27:11 PM | Importing an inventor file into revit mep
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
that is very old, do not save as a SAT file. Inventor files can be saved as ADSK files which can be opened directly into Revit and can retain connection properties.
here is also some new tech for Inventor to Revit
http://labs.autodesk.com/utilities/bim_family_toolkit/
Edited on: Thu, Jan 20, 2011 at 2:36:19 PM
Thu, Jan 20, 2011 at 5:22:10 PM | Importing an inventor file into revit mep
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
The BIM Toolkits are a great step toward the problem although it is still in labs... I blogged about this quite awhile ago...the best use is to work with the AEC Exchange and shrinkwrap or do a substitute...this process will kick out a an ADSK file that can be read by Revit.
 http://familyjewels.typepad.com/blog/2010/06/aec-exchange-1.html
Importing from Inventor
Mon, Mar 8, 2004 at 8:49:44 AM
Inventor to Revit Structure 2010 or 2011
Fri, Dec 10, 2010 at 5:45:29 AM
How do i convert Inventor 09 file to a file i can loan into revit 09
Wed, Mar 25, 2009 at 8:30:27 AM
Inventor adsk file in revit.
Thu, Oct 14, 2010 at 8:48:45 AM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Page generation time: 1.8451
