Forums >> Revit Building >> Technical Support >> revit arch 2011 - elevation and 3d views with shadows!
Mon, Jan 10, 2011 at 2:59:15 AM | revit arch 2011 - elevation and 3d views with shadows!
tommytucker
hey,
 when i activate shadows on my elevations and 3d views they immediately take on  a halftone appearance, its well annoying, how do i turn this (halftone appearance) off?
thanks in advance,
tom
Thu, Jan 13, 2011 at 8:57:48 AM | revit arch 2011 - elevation and 3d views with shadows!
TeamNga
1 Stars: 1 Votes
Hello Tommy.
If you click on the Shadow on/off button there is a Graphic Display Option...
Select that. In there you will find a Cast Shadow check box with a Lighter/Darker setting that is set to 50 by default. Adjust it to your liking.
Thu, Jan 13, 2011 at 7:17:45 PM | revit arch 2011 - elevation and 3d views with shadows!
tommytucker
sorry i havent been very clear.
 i can already adjust the shadow brightness.
when i activate shadows all the linework of the 3d model goes from black to grey, purely because shadows are activated and irrespective of the shadow density / brightness.
it is this halftone appearance i want to control, i.e. i want my 3d models and elevations to appear to have black linework, not halftone / grey.
how do i fix this?
thanks againtom
Fri, Jan 14, 2011 at 8:18:09 AM | revit arch 2011 - elevation and 3d views with shadows!
I don't think you will be able to do what you want.  Once shadows are turned on, the view will have to be printed as raster rather than vector.
shading and shadows in 2011
Fri, Dec 9, 2011 at 8:52:08 AM
any work around for this? transparent glass in shaded elevation views, revit 201
Mon, Jan 28, 2013 at 11:19:53 PM
Elevation Shadows
Sun, Jun 2, 2013 at 11:46:24 PM
Revit 2011: Linked model not displaying casting shadows
Tue, Sep 28, 2010 at 1:55:13 PM
can't see shadows on neighbours walls.
Tue, Aug 25, 2009 at 7:35:36 AM
Page generation time: 1.7994
