28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Work area disapered
69 Posts No Rating |
I have what to me is a strange issue. When I open a file, the work area is covered with the browser and the properties. I can turn these off and the drawing area is there, when i turn on for exsample the project browser again, it covers the entire work area and there are no grab areas to reduce it so the drawing can appears This is for all the projects and only on this computer I know my way around most area of Revit and from experience, there must be an easy solusion. I am also sure the fix is soo simple, I kick myself when I get to know Anyone want to let me know?
13 Posts No Rating |
Hi Erik. I´ve had this happening a few times, and have used this fix. Cheers
Edited on: Mon, Jan 10, 2011 at 3:36:15 AM
-Munkholm
www.revitforum.org |
Takk skal du ha. Wah, that was not that straight forwward solution as I thought. No reason to kick myself :-) It certainly worked, thank you
Room tags with area - area not showing up! |
Thu, Aug 16, 2007 at 6:54:26 PM
incompatible area tags |
Sat, Jan 14, 2006 at 1:57:46 AM
Area Plan does not match Area from Materia/l Area |
Tue, Feb 13, 2018 at 7:50:03 AM
Area Tag issues |
Tue, Dec 12, 2006 at 9:45:15 AM
Area Tags |
Tue, Jan 22, 2008 at 2:00:35 PM
