Forums >> General Discussion >> Wishlist >> Wishlist - Element re-number
Fri, Jan 7, 2011 at 5:39:20 PM | Wishlist - Element re-number
archiboi
3. Element re-number!
Autodesk hang their hat on Revit’s scheduling capabilities, but really it’s just a BIM standard capability. Revit’s standard window and door numbering system is a mess. Renumbering is a tedious task, and honestly, not very BIM. Look at Archicad, or Avetec and or particularly Kiwi Codes add-ins.
Sat, Jan 8, 2011 at 8:54:18 AM | Wishlist - Element re-number
I don't know what problems you are having with the door or window numbering.  I renumber them easily.  Some things to remember:
  1. Door and window numbers can be duplicated.
  2. ....so if you want multiple doors numbered them all from a floor plan or schedule and change their number
  3. Automatic numbering is sequential from the last unit added.  So if you are adding doors on the second floor and want them in the 200's ... number the first 200 and the second will be 201....
Sat, Jan 8, 2011 at 6:45:28 PM | Wishlist - Element re-number
archiboi
Thanks for the reply... but i find the current proccess of having to renumber windows and doors by selecting, typing a mark value, select the next one, change the value, time consuming and very 'autocad'. Windows are numbered progressivly clockwise around the building (yes?), revit makes no attempt to understand this fundumental drafting procedure.Why are there no options when placing windows like, 'insert at end', or 'keep clockwise order'? this would be a hell of a lot more intuitive and understanding of the documentation proccess. There are even add-ins that will alow you to click renumber from the floor plan view, that automatically move duplicate mark values to the end.
Tue, Jan 11, 2011 at 8:40:47 AM | archiboi
snowyweston
"Windows are numbered progressivly clockwise around the building (yes?)"
No. At least not in our office* - so any feature request like this would need be user-definable, rather than absolute.
I agree though, some form of cascade/domino-effect when making revisions to sequences in a project, based on rules, would be nice.
*We've a spectacularly complicated number "system" (that we presently use the MARK field for) which is essentially a composite of other information; that defines family (W,D,S,C... for window, door, etc) room number, and then an alphabetic count per room... for a long while I wanted our tags to read the three components of the "number" from three different fields, but the "duplicate mark" errors stopped that idea flat.
**I really can't get the hang of this site's post-editing.
Edited on: Tue, Jan 11, 2011 at 8:47:01 AM
Thu, Dec 1, 2011 at 7:14:26 PM | Wishlist - Element re-number
CADdaddy
Take a look at my renumbering addin tool at www.caddaddy.com/software/Revit. James
Thu, Mar 15, 2012 at 7:01:17 AM | Wishlist - Element re-number
archiboi
Love it... Now if you had a plugin for a working doors and windows schedule that displays associated room areas with light and ventilation (required & provided), i'd be your best friend.
Fri, Mar 16, 2012 at 4:29:39 AM | Wishlist - Element re-number
mathill
http://labs.autodesk.com/utilities/roomrenumbering/
You can get this room/door renumbering plug in from autodesk labs - Does this mean it might be in the next version?
Mon, Mar 19, 2012 at 9:44:54 PM | Wishlist - Element re-number
archiboi
Mathill,This is exactly what I've been looking for... and it's come from Autodesk. *shocked*I've blasted Autodesk on multiple occasions regarding these type of things. Seems they're listening after all.Cheers
I Need Sheet Number or View Name into Model element parameter
Thu, Feb 27, 2014 at 1:35:49 PM
Wishlist
Workflow & Implementation >> Chameleon
Wed, Apr 24, 2024 at 12:22:03 PM
AUGI Revit Wishlist
Mon, Oct 8, 2007 at 8:54:14 AM
Element positioning
Thu, Nov 13, 2014 at 7:47:01 AM
View Schedule with Sheet Number & Detail Number
Thu, Sep 1, 2016 at 12:07:37 AM
Page generation time: 3.4992
