Forums >> Revit Building >> Technical Support >> Glass panel railing help
Fri, Jan 7, 2011 at 11:08:54 AM | Glass panel railing help
arusso5
I'm using both Revit Architecture 2010 and 2011 and I have a residential client who wants a railing that is glass panels with aluminum rails and balusters.  I have attached a few pictures of what he wants.  I found a similar railing and have modified the rails and balusters, but I can get the glass width to adjust.  The glass panels are 24" wide.  My railing is set between 12" posts that are independent of the railing so if the railing section is only 4' long, the railing centers i pice of glass in the railing. Please see attached view.  Can anyone help me solve this?  It's quite frustrating.
Fri, Jan 7, 2011 at 12:43:55 PM | Glass panel railing help
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
think I would do it with storefront for the wall portion with a separate rail, just a thought you will need to maintain only 4" clear openings I think
Fri, Jan 7, 2011 at 3:23:21 PM | Glass panel railing help
Bimman
Bimman Avatar
1 Stars: 2 Votes
I WOULD DO IT AS INPLACE FAMILIES USING EXTRUSIONS AND SWEEPS. SETTING THE MATERIALS FOR THE PIECES AS I DESIGN THEM.  ARE THE PANELS YOU WANT TO ADJUST INPLACE FAMILIES. IF SO YOU WILL NEED TO EDIT THEM INDIVIDUALLY. MAY BE THE REASON YOU CANT GET THEM TO ADJUST.
PWD
railing with glass or solid
Wed, Apr 30, 2008 at 5:28:23 PM
R2020 - Glass Railing
Fri, Jan 24, 2020 at 10:36:28 AM
Glass panel railing
Fri, Apr 7, 2006 at 3:36:44 PM
Glass Panel Baluster Issue
Wed, Nov 2, 2011 at 4:13:25 PM
12
Glass Railing
Wed, May 5, 2010 at 3:11:19 PM
Page generation time: 0.1480
