Forums >> Workflow & Implementation >> API & Third Party Apps >> Converting Revit.DB objects to Revit.Geometry objects
Fri, Jan 7, 2011 at 10:48:49 AM | Converting Revit.DB objects to Revit.Geometry objects
davidr
I run across this one a lot.  How do you convert Revit.Geometry objects to Revit.DB objects.  For example, i need to take a View and pull the boundingbox from it, but the code won't let you do it because it says you cannot convert a Revit DB (view) object to a Revit Geometry object (boundingbox)!   So how do you handle this?
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:58 AM
New to Revit, converting from CAD questions
Thu, Apr 28, 2011 at 10:22:40 PM
Converting ArchiCAD objects into Revit families
Thu, Jan 17, 2013 at 9:43:29 AM
Converting 3D objects from ADT to Revit families? Any suggestions?
Wed, Nov 22, 2006 at 11:35:48 AM
Importing .3ds objects into revit OR a WORKAROUND??
Fri, Aug 7, 2009 at 10:23:19 AM
Page generation time: 1.4977
