Forums >> Revit Building >> Tips & Tricks >> damp proof membrane in section
Fri, Jan 7, 2011 at 9:55:37 AM | damp proof membrane in section
iangus
ok ive a floor construction basically nothing but say 150mm concrete sat on a dpm. when cutting sections traditionally in autocad the dpm would show as a dashed line. is this possible in revit? (without just adding a dashed detail line).
Fri, Jan 7, 2011 at 10:00:28 AM | damp proof membrane in section
Sorry no - we add the dashed lines.
Fri, Jan 7, 2011 at 4:30:34 PM | damp proof membrane in section
stealthnyc
4.5 Stars: 2 Votes
You could add a substrate layer about an 1" thick and then use the linework tool to change the bottom line to a dashed line and the interior line to a darker cut line.
Fri, Mar 18, 2011 at 8:32:16 AM | damp proof membrane in section
cadboi08
Maybe add a layer to floor structure, then linetype tool as needed?!
Check out RevitTube for Awesome Revit Videos Daily - https://www.youtube.com/channel/UCl-rjEtxDTE0DOrtqOV8aKw
What's the Point of the Membrane Layer
Mon, Nov 11, 2013 at 5:11:55 PM
Tensile Membrane Structures [ 1 2 ]
Fri, Oct 1, 2004 at 10:43:14 AM
21
Errors using Membrane Layer: zero / non-zero thickness
Wed, Aug 7, 2013 at 6:08:50 PM
Kenoting a Membrane Layer (0" thickness)
Sat, Feb 12, 2011 at 12:23:27 PM
Displaying membrane layers as dashed lines in detail view
Mon, Jun 9, 2008 at 3:43:11 PM
Page generation time: 0.1945
