18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Sloped Grade Beam in Foundation Plan
1 Posts No Rating |
How can I draw the sloped Grade Beam in Foundation Plan ? We only have the staight grade beam in library. Can I use the sweep ? Thanks, Huong
Beams are workplane based, so create a reference plane at the slope you want to draw you beam at and set that as the host, or draw the beam in a section or elevation view. Alternatively, model a foundation slab and add a slope arrow to define the slope. HTH.
Regards,
Chris.
Sloped terrain and sloped foundation wall |
Thu, Sep 3, 2009 at 1:57:36 PM
Pier caps in Grade beams |
Mon, Aug 29, 2011 at 2:01:13 PM
Stepping foundation wall to follow grade |
Fri, Nov 9, 2007 at 1:57:53 PM
foundation |
Tue, Jul 17, 2018 at 10:41:10 AM
Sloped Beam? |
Thu, Dec 15, 2005 at 3:38:36 PM
