Forums >> Revit Building >> Technical Support >> angling ends of an extruded shape
Wed, Nov 2, 2005 at 6:10:12 PM | angling ends of an extruded shape
arccodex1
3 Stars: 1 Votes
It would be nice if one could angle ends of an extruded shape without having to generate a void to cut the end or begining of an extrusion at an angle.
Thu, Nov 3, 2005 at 5:20:54 PM | RE: angling ends of an extruded shape
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Why couldn't you just create the extrusion with the angle to begin with... Provided its extruded in the correct plane.
Thu, Nov 3, 2005 at 5:48:01 PM | RE: angling ends of an extruded shape
eldados
eldados Avatar
4.5 Stars: 8 Votes
...or sweep on a path??
Integrator
KarelCAD
Thu, Nov 3, 2005 at 6:59:34 PM | RE: angling ends of an extruded shape
arccodex1
3 Stars: 1 Votes
Because the nosing I need is in the X-Z plane and the angle I want is in the X-Y plane. The nosing is on one edge only so a sweep wouldn't work. Post edited on 2005-11-03 19:01:16
Thu, Nov 3, 2005 at 7:00:43 PM | RE: angling ends of an extruded shape
eldados
eldados Avatar
4.5 Stars: 8 Votes
show us what you need...
Integrator
KarelCAD
Thu, Nov 3, 2005 at 7:03:30 PM | RE: angling ends of an extruded shape
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What is the issue with having to create a void?
Thu, Nov 3, 2005 at 7:38:49 PM | RE: angling ends of an extruded shape
arccodex1
3 Stars: 1 Votes
We have a deep window sill in a doubled wall and the condition occurs many times along the elevation. It would just be cleaner if you could angle the begining and end of a extruded shape instead of having voids all over the place.
Thu, Nov 3, 2005 at 10:10:37 PM | RE: angling ends of an extruded shape
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm, couldn't you just create the shape as an adjustable element and place each of them as a wall hosted family or alike.. Bit hard to comment without a pic.
Fri, Nov 4, 2005 at 11:55:44 AM | RE: angling ends of an extruded shape
arccodex1
3 Stars: 1 Votes
The extrusion is from left to right. The ends of the sill are angled because of the window opening. An adjust able element?
Fri, Nov 4, 2005 at 5:23:12 PM | RE: angling ends of an extruded shape
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
It looks as though the window is hosted by one wall, then another wall is drawn external to this and you've then created an opening in this wall. Is this the case? For the wedge form opening, create a generic wall hosted opening (so it doesn't schedule, unless you want to schedule this opening in addition to the window?) by using the Void-->Blend option in elevation on the wall and making it parametric. Constrain to the faces of the wall and voila. It would then just be a matter of placing the opening in front of all the appropriate windows and adjusting its size to suit. Assuming this is what your trying to do...
Fri, Nov 4, 2005 at 6:04:01 PM | RE: angling ends of an extruded shape
#11
arccodex1
3 Stars: 1 Votes
We used two walls and just inserted the window into the exterior wall leaving us with a deep interior sill. A solid blend would work fine if we didn't have a rounded edge (hard to see but in the first picture) at the edge of sill. Ultimately we just created a generic family for the sill and used voids to cut the angled ends of the extruded shape. There are probably several ways to model this geometry it just would have been neat if one could angle the ends of an extrusion. Thanks for the input. Post edited on 2005-11-04 18:04:59
Sat, Nov 5, 2005 at 12:55:05 AM | RE: angling ends of an extruded shape
#12
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Fair enough. In which case i would've just a blend and sweep. But suppose that puts us pretty much back where we started...
Can you extrude a profile?
Fri, Dec 19, 2008 at 2:02:50 PM
Family With Multiple adjustable elements
Mon, Sep 26, 2011 at 2:53:17 PM
Extruded roof - surface pattern displaying incorrect
Wed, Sep 8, 2010 at 10:00:11 AM
creating column based with carvings
Wed, Oct 5, 2005 at 6:01:29 PM
Custom rafters/roofing Revit 2012
Mon, Sep 23, 2013 at 6:28:08 PM
Page generation time: 1.7694
