Forums >> Revit Building >> Technical Support >> Fill pattens below pads
Thu, Jan 6, 2011 at 2:42:47 PM | Fill pattens below pads
kansascity
Can someone help me understand why my plans will display a void under a pad.  I have a building cut into the topography. the lowest level is smaller in plan than the level at grade.  At the 1st floor( lowest level) plan the earth fill pattern from the topography is present except where the upper level footprint is extended, in these areas it is blank.    phase filter is set to display show all.   in section the areas under these pads appear do not highlight when i select the rest of the topography
Drawing an filled region is not acceptable solution.
Thu, Jan 6, 2011 at 3:08:13 PM | Fill pattens below pads
pchan
pchan Avatar
5 Stars: 5 Votes
Have you tried the paint bucket to paint the surface?
Thu, Jan 6, 2011 at 3:20:58 PM | Fill pattens below pads
kansascity
 there doesn't seem to be anything  there to paint.
CUT AND FILL - PADS WHICH DO NOT SHOW C&F VOLUME ON A SCHEDULE
Tue, Feb 13, 2018 at 4:37:06 AM
Revit Cut and Fill
Thu, Jan 13, 2011 at 5:02:33 PM
CUT AND FILL
Tue, Dec 9, 2008 at 5:31:09 PM
Scheduling cut and fill when using split regions
Sun, Sep 21, 2008 at 8:56:58 AM
Topography and pads trick
Mon, Jan 14, 2013 at 2:53:18 PM
Page generation time: 0.8550
