Forums >> Revit Building >> Technical Support >> Conceptual Mass Color-Unable to Edit Type
Wed, Jan 5, 2011 at 4:55:19 PM | Conceptual Mass Color-Unable to Edit Type
mjhunton
I've read several forum entries that discuss how I can change the color/material of a conceptual mass by editing it and adding a paramter or simply changing the material. The issue I am having is that when I select the mass I have created and then select "edit type," there is no parameter in the list that is a material. Also, under the Family and type drop down, there is nothing to select...
 The Parameters I do have are under "Identity Data": Keynote, Model, Manufacturer, etc...nothing about material or color.
 What am I missing? I am fairly new to this and I've been stumped on what seems to be a really easy task!
Unable to load conceptual mass into project
Fri, Sep 11, 2015 at 1:40:26 PM
conceptual mass problem
Fri, Jan 13, 2012 at 4:02:05 PM
conceptual mass -newbie to that
Mon, Feb 21, 2011 at 9:21:36 AM
Scaling Conceptual Mass
Mon, Oct 11, 2010 at 7:34:51 AM
Update Structural Framing with Updated Conceptual Mass?
Thu, Mar 12, 2015 at 6:54:55 PM
Page generation time: 0.5188
