Forums >> Revit Building >> Technical Support >> Figuring out facades
Wed, Jan 5, 2011 at 8:44:38 AM | Figuring out facades
oliveOil
Hello. I'm working on some facades. I don't exactly need instructions on making this in Revit but I'm more interested in figuring out how it's actually made and then I can figure out how to do it in Revit. I've attached some pictures of the ideas I want to use.
Any other suggestions for some similar nicely looking facades are welcome.
Thanks!
Wed, Jan 5, 2011 at 10:48:44 AM | Figuring out facades
You have posted multiple buildings and asked a very broad question.  Please post one building and clarify your question.
Wed, Jan 5, 2011 at 1:49:50 PM | Figuring out facades
pchan
pchan Avatar
5 Stars: 5 Votes
I always think the ways Revit work (most of the time) is the way of how we put the building together.
so it depends on how the facade design is, then you would use the right set of elements to create the facade.
Lots of time I heard people misuse the tool (like using roof as a floor, or use curtain wall as a railing), would not good when the project is a team effort other than by yourself. There is always an exception to any unique situation, so any trick/workaround need to be implemented (in-place family).
To answer your question, it seems like typical (basic/composite) wall, curtain walls,  door and windows should do just fine.
Philip
Panels for facades
Mon, Jan 8, 2007 at 6:44:30 AM
HUGE FILE---ALMOST 1000MB
Thu, Aug 24, 2017 at 12:59:26 PM
Help with Facades of Photos
Mon, Aug 30, 2004 at 4:56:45 PM
Best method to draw architectural facade - pdf attached
Wed, Jul 24, 2019 at 10:00:54 AM
Pergola
Thu, Jul 22, 2010 at 11:18:30 AM
Page generation time: 1.3837
